I have an 86 BII with a 2.9 thats not getting any fire. I changed coils and still nothing which now leads me to wiring. I have charge on my red wire going into the coil so i'm thinking the light colored blue/greenish wire. Can I straight wire this and where does it go? Any suggestions would greatly be appreciated!
01 sport trac 4x4 black
97 explorer xlt AWD v8 blue
91 f-250 xlt lariat 4x4 blue/gray
84 ranger xlt 4x4 black
94 explorer xlt 4x4 purple/gray
96 explorer limited 4x4 green
What purpose does the green wire hold? I have both wires cut right past the coil. I can connect the red wire and the green wire will show a current on it coming out of the coil. But still no fire. Can I bypass anything and make the coil fire? I was told if the low pressure fuel pump wasn't connected it wouldn't fire. I was four-wheeling and somehow ripped the wiring harness loose from my tail lights and low pressure pump. All I use it for is to play so I'm not real worried about it if I can get by without them. Any suggestions?
Hey, it can't be the wire harness to the fuel pump. It does not control the fire to the ingnition. If I was you, replace the harness and then check the realys located on the right side of the firewall(By battery behind air filter). There should be a black and green(maybe gray or brown.) The black or brown one controls the coil charge up by relaying a signal from the computer. Mine went out and my truck would crank like no other but would not start. I replace it(actually just splice the red and oragne wire together, i recommend the realy replacement or buying a 30 amp fuse kit and replacing it becuase fuses are cheap.) The wire harness probably grounded out though and toasted ur relays. They are $25 dollars for both at AutoZone.
Thanks for the advice AKA! I was going through the wires today and did find that the red wire led to the black relay. I rewired the ripped of portion of that wiring harness which in turn got my gauges and lights working. I was also checking for fire again, I had a plug in my coil wire, and when I would turn it over nothin but if I turned the switch to the off position befor the motor stoped turning it would fire for a split second and would always do this as long as I would turn the switch back.????? Any Ideas now? I will try splicing those wires at the relay and check again. Oh and I also changed the moduler on the side of distributer and it made no difference. Thanks for everyones help!
