Bronco II Ford Bronco II
Rear axle problem ??
Old Oct 9, 2002 | 07:50 PM
jpm2591's Avatar
jpm2591
I bought an 88 5 speed that had a bent driveshaft. I replaced the driveshaft. There is side-to-side slop at the pinion flange, most likely from driving with the bent axle. At highway speeds as I'm going downhill and letting up on the accelerator I get an annoying vibration. If I let off the accelerator completely the vibration stops or if I would give it more gas when the vibration starts it will also stop. I am assuming the problem is from the pinion flange slop. Any suggestions on how to fix. Thank you!
Old Nov 4, 2002 | 01:47 AM
78muddinman's Avatar
78muddinman
I had that exact same problem on a 1990 Jeep Cherokee and on my 1978 F250 Highboy. Both times it was both U-Joints at the ends of the driveshaft. You might try checking them.
Old4xford
Old Nov 15, 2002 | 10:57 AM
magnus's Avatar
magnus
Look at the front pinion bearing, it may have been damaged too.
Old Nov 15, 2002 | 11:01 AM
magnus's Avatar
magnus
jsmorris
Jul 16, 2009 08:45 AM
SLE
Jun 5, 2007 09:21 PM
Merculous
1997 - 2003 F150
May 9, 2007 02:07 PM
