anyone got a custom headliner?
Old Sep 21, 2004 | 08:46 AM
nate5812's Avatar
nate5812
i'm not crazy about the factory ones and was thinking of trying to make one maybe out of metal.like to see some pictures
Old Sep 21, 2004 | 01:57 PM
Colo79Ford's Avatar
Colo79Ford
MInes not too far custom, but i just took the stock one and carpeted it with that cheap carpeting like people can use for speaker boxes, changed the whole look of the interior to me, but no one else seems to notice, go figure. Looks 10 fold better than stock too.
---JOHN
Old Sep 21, 2004 | 03:03 PM
19gator55's Avatar
19gator55
Mine was pretty much trashed. What I did was buy a sheet of white masonite from Home Depot and then use the old headliner as a template to cut out the new one. You can also use paneling for a woodgrain finish. The advantage to using the white masonite is that I can write on it with the erasable markers and just wipe it off when I no longer need the message. A built in note pad. You may have to make the front to back depth just a little bit shorter as the masonite or paneling isn't quite as flexible as the original headliner. I had to cut mine down about 1/4" which I did after test fitting it.
Old Sep 21, 2004 | 07:28 PM
andy79's Avatar
andy79
I did the same as Colo79ford. But I used black vinyl instead of carpet. Turned out real nice.
Old Sep 21, 2004 | 08:31 PM
highboy1975's Avatar
highboy1975
the guy that had my truck before me put fleece material over my headliner. tiger print, lol
Old Sep 21, 2004 | 08:43 PM
matt77F2504x4's Avatar
matt77F2504x4
mine is peeling off and i think im going to put a piece of laminate on it. you can get just about any pattern or look that you want!
