Do I need the high pressure pump?
Old Sep 21, 2004 | 08:28 AM
kij2004's Avatar
kij2004
Question Do I need the high pressure pump?
I have an 87 f150 that I am currently planning on swapping out the 302EFI for a carbed 351W. The high pressure fuel pump is bad. I know I don't need all that pressure for the carb but will the in-tank pumps (duel tanks) be sufficient or should I replace the high pressure pump? I'm sure this question has been asked before but......
Frank
Old Sep 21, 2004 | 08:45 AM
pfogle's Avatar
pfogle
You need to remove the in tank pump. Put a piece of hose with a screen on the end of the hose, and then use an external electric low pressure (7psi) or mechanical pump.
Old Sep 21, 2004 | 09:32 AM
EPNCSU2006's Avatar
EPNCSU2006
I would just regulate the pressure from the in-tank pumps. They are pretty low pressure to begin with (not sure their exact rating), and you could probably get by doing this so long as you have a regulator. Definitely don't replace the high pressure pump.
