Acceleration stalling & backfire????
I found a loose vaccum line under my hood a couple months ago, and my performance is hurting a little now, it seems I have no torque.. I looked for places it could've gone but I can't find any. Does any body have pictures of how a 2.9L is supposed to look with all the vaccum hoses in place? The previous owner of my B2 must of liked grey tape, because there's quite a few places that look like they should have line's hooked up to them, and they have duct tape on them clogging them. I was thinking that my B2 didn't have enough power, even though they aren't a powerhouse, but I raced a kid with an 89 B2 (mines a 90) and he didn't have anything special in his, but it felt like he smoked me, so I'm thinking that the unhooked vaccums are hurting performance levels, and also I should be getting about 18 mpg and I'm getting about 14 maybe this is a cause of this too? Sorry, I didn't want to make a seperate thread about something simple.
Then run the pinpoint tests, I can email them to you if you need them.
13 = IAC
72 = MAP
73 = TPS
74 = BOO, did you hit the brakes when prompted?
41 = O2, don't worry about a continuous code until you clear all the KOER codes.
When the IAC is disconnected it idles down and starts to stall. Also tested the connector, it's fine.
Tested the connector for the TPS, is is fine. Not sure how to test the Sensor itself though. I think I'm just going to replace this one as the one I have has some wear (chips) in it.
MAP Sensor vacume disconnected also idles it down, becomes erratic and trys to stall. I didn't pull the electrical loose to test it.
And no, I didn't hit the brakes at prompt, didn't know I was supposed to until afterwards.
I'll test again tomorrow and see how it goes.
74, like Ken said, probably means you missed pressing the brake jsut afiter engine id output.
Teh 13 is probably symptomatic, rather than diagnostic. Check teh IAC carefully to see if it's dirty or what not. If you don't find aproblem, then go on to the CM 41
CM41 tells us that the O2 sensor idicated lean at some point during operation. The fact taht you didn't get a KOER 41 suggests that whatever fault is creating teh 41 is intermittent. After checking teh IAC and making sure to run teh KOER test correctly, clear the CM codes (disconnect jumper wire during KOEO/CM code output), then drive it and see under what conditions the 41 comes back. also be sure to check the wiring from the sensor to the computer for any obvious faults.
I pulled the IAC off a couple days ago and cleaned it thoroughly. It looks clean as new. I also checked the connection and it is good, at least when I tested it.
I'll run the codes again tomorrow (weather permitting) and see what happens.
Just want to say THANKS to all of you for your help. I never was really good with vehicles, but I have learned more on this site in the last 4 months then I ever knew before.
KOEO - 11
Memory - 63
KOER - 98 "Hard Fault Present" .....(and 63 but only on the first of three tests)
My Check Engine light is still on since yesterday and my Charging/Alt light flickers on/off, but has been since I've had it. The battery is fully charged and a volt-meter shows 15.0 volts with the motor running and 12.0 with it off. Bad battery cable maybe? The Neg cable looks like it could be replaced but if that isn't the problem I'd just as soon leave it alone.
Ideas?
I pulled the TPS off and started checking the sensor and the harness connecter. The sensor tested fine, once I reread how to check it like 10 times.
The harness connecter checked fine at first but I started looking at it realy close and discovered that the C clip didn't look right. I messed with it a little and the wire popped right out. I reattached it, plugged it back into the TPS, and started it up. The idle seemed more calm and even and was at about 1150 RPM's. I drove it around the block (900 RPM's in Drive) and it drove better then it did when I first got it.....better accereration, response, and power. The Check Engine light is still on and the Charging/Alt light continues it's on/off thing. Also, the ABS light is on now....have no idea about that one.
I'll pull the codes again when the storm passes over, so probably tomorrow.
Check the belt tension and electrical connections for the alt but it might be on its way out.
I have the procedure for pulling the RABS codes in the tech info thread, us the one for older trucks.
- Input = 4.82 volts
- Closed throttle = .41 volts
- WOT = .35 volts
The TPS on my B2 has to be set in place and turned slightly clockwise to be secured on. Doing it this way resulted in almost 4.5 volts at closed throttle and made the engine continue to rev up until I turned the engine off......over 5000.
I'll be replacing the TPS. I'm not going to pull the codes again until then.
The RPM's are high at about 1500 to 1600 in Park and about 1000 to 1100 in Drive, the RABS and the CEL are on but at least it is drivable until I get the new sensor.
Thanks everyone.
7y3
Turns out, I was just low on gas, and that some of that "Gas tank grudge" had just worked it's way into my engine.
I filled the tank with some Premium gas, and I was good to go.
No more backfiring, stalling, sputtering, erratic shifting, and the CEL and the RABS lights are now out.
Now there's more power, faster and more responsive acceleration, the cruise works great again, and the idle is as smooth as silk at 800 to 850 RPM's in Park.
KOEO - 11
Con Mem - 11
KOER - 11
Thanks everyone!!
