Brake Problem After PCV Re-Route
Old Sep 20, 2004 | 10:51 PM
nickcletus's Avatar
nickcletus
I re-routed the PCV outlet from the 8th cylinder into a tee on the brake booster vacuum line (about an 1 1/2 inch away from the booster) Since i have done this my brake pedal is very hard. I have to throw my foot in it to stop. Could this be because I have the vacuum splice too close to the booster, should it be closer to the vacuum tree on the intake.
Old Sep 21, 2004 | 06:56 AM
EPNCSU2006's Avatar
EPNCSU2006
I would not route the PCV into the brake line at all. It's like electrical circuits - the air in this case will take the path of least resistance. Instead of pulling a vacuum in the brake booster line, manifold vacuum is pulling air from the pcv system and not allowing vacuum to be built in the booster.
Old Sep 21, 2004 | 07:17 AM
GermanGuy's Avatar
GermanGuy
Question
nickcletus....I would be interested to know where in the PCV line setup you have found a vacuum line at all?
Dieter
Old Sep 21, 2004 | 06:48 PM
nickcletus's Avatar
nickcletus
I must have done the pcv re-route wrong. I thought you took the pcv push on fitting on the valve cover and routed the hose into the vacuum tree on the the upper intake but i didn't have an open line so i put a tee in the brake booster vacuum line. I thought this helps the 8th cylinder from blowing easily and smooths out the idle. If i did this wrong could help me fix it.
Old Sep 21, 2004 | 06:57 PM
mike93's Avatar
mike93
try using the cruise control vacuum line if you have one, but keep the tee on the engine side of the check valve.
