Sponsored by: Innova
Subwoofer Making Odd Noises...
Old Sep 20, 2004 | 08:33 PM
MemOrex's Avatar
MemOrex
One of my 12"s is making some weird, almost rattlin noises if you listen to it closely... It still plays bass real good, so its not blown. Is it ruined? I have the 2 12's paralleled, could this cause problems? This happened also to one of my other subs that i had a while back, so could the amp be a problem?
Old Sep 20, 2004 | 09:04 PM
1969FordF250's Avatar
1969FordF250
How loud of a rattling noise is it? The screws in my speakers loosen up every once in awhile and make a slight rattling noise. Try tightening the screws. Also, the cardboard looking thing (ontop of the magnet) sometimes comes loose so if you can find a good glue you can glue it back on. Hope this helps.
Old Sep 20, 2004 | 09:58 PM
shanesF150's Avatar
shanesF150
it could be that your just so close to the sub
but maybe something came apart and you can probly fix it like the other
person said
Old Sep 20, 2004 | 10:20 PM
bill6302's Avatar
bill6302
check the dust cap. it might have come off at one point and would make that noise.
Old Sep 20, 2004 | 10:57 PM
MemOrex's Avatar
MemOrex
Its not real loud, it just annoys me. I dont think its cuz im too close because the other would do the same. I hope it is something that just needs a little glue. Now that i think of it, it might be the dust cap like bill said. Thanks for replies guys.
Old Sep 21, 2004 | 01:52 AM
pounder90's Avatar
pounder90
Make sure your amp is grounded well. My sub was making a weird vibration/hum on occasion. I finally pulled the amp ground wire and cleaned up the connection to the frame and retightened it. Works like new.
Old Sep 21, 2004 | 03:31 PM
PrPlayboy's Avatar
PrPlayboy
Also take the sub out and inspect it. See if the tinsil leads are too loose. Check for loose screws that may be letting air out. It might be the voice coil slightly damaged.
kodiak_f250
Jun 18, 2020 04:45 PM
wagne020
May 12, 2016 10:38 PM
M-S-G
22
Jun 15, 2015 11:41 PM
bodnarm
Sep 3, 2014 06:34 PM
TopoGeorge
May 14, 2008 10:17 PM
