ABS light blinking
Old Sep 20, 2004 | 08:28 PM
stutterstan's Avatar
stutterstan
ABS light blinking
Hey, I'm new to this forum, so I am looking for some kowledgable people. 93 F250 351W, The ABS light blinks 16 times, stops for a second, then starts blinking again, already replaced the senor on the rear diff, not the fix. Any ideas is greatly appreciated
Old Sep 20, 2004 | 11:48 PM
andym's Avatar
andym
You can have the codes pulled from the ABS computer from a brake shop. It could be just about anything in the ABS system.
Old Sep 21, 2004 | 08:06 AM
ssn randy's Avatar
ssn randy
seen this once. ABS takes a certain amount of voltage. both battery and alt work together to supply it. if battery is to weak to supply its share or alt to weak, the light will blink. check the outputs on both. Also, I agree with ANDYM, have the codes pulled, this could save expensive fix/ guessing in the long run.
Old Sep 21, 2004 | 10:27 AM
reese4's Avatar
reese4
Had the same exact problem as you about two weeks ago. Turns out, one of my trailer wiring harnesses worked its way loose and was coming into contact with my rear bumper. This caused one of the fuses in the fuse panel to blow. Just double check and make sure all your fuses are good before you look into any other solutions.
scrooge
Escape & Escape Hybrid
Nov 23, 2013 11:08 PM
Fastfwd
Aug 22, 2013 10:02 AM
Branny08
Apr 2, 2012 07:02 PM
WalleyeHunter
Dec 16, 2004 10:15 AM
nothingbutford
Sep 4, 2001 12:08 AM
