tranny shifting wrong
Old Sep 20, 2004 | 06:54 PM
Lesspaul's Avatar
Lesspaul
tranny shifting late, too much fluid?
Hi, I have a 1996 F-150 with a 5.0. I changed the transmission filter and fluid, now it's shifting late. Could this be due to too much fluid added? The dipstick reads about a quarter inch over the "zone" after about 5 minutes of driving. If so, how can I drain some out? It's a E4OD I believe.
Old Sep 20, 2004 | 07:04 PM
noogie102283's Avatar
noogie102283
to much fluid is never a good thing. i added to much once but just siphoned it out with a small hose.to much fluid aerates in tranny and puts more wear then you want.
my .02
Old Sep 20, 2004 | 09:13 PM
Lesspaul's Avatar
Lesspaul
Thanks for the .02. I took off the plenum and cleaned it out yesterday along with IAC motor. I found a small vaccuum end cap lying on the intake manifold. The check engine light is on and the transmission is acting up, shifting wrong. I checked all over for a vaccuum leak but found none. Please throw in some more cents. Ken
Old Sep 21, 2004 | 07:52 PM
Lesspaul's Avatar
Lesspaul
Turns out it was the TPS, I did not have it positioned correctly. On my 1996 302 FI, the TPS has to be turned toward the IAC motor and then rotated counter-clockwise into position. Thanks.
