Ford axle decode
Old Sep 20, 2004 | 06:47 PM
fordtruckenthusiast's Avatar
fordtruckenthusiast
Ford axle decode
I recently purchased a junked '81 f250 4x4 standard cab with a 4.9 I6. I'm almost a 100% sure that I'm reading the door tag right, it says "37" for the axle code. I haven't been able to find anything that lists a 37 as anything. I need an assist for this one. Thanks in advance.
Old Sep 20, 2004 | 07:10 PM
mustange70's Avatar
mustange70
yeah I'm in the same boat only i have an E-350 bus with a 460 and a C6 with an axle code of 33, and i haven't been able to find anything. However if it was a limited slip (a letter in the code such as H or a D) a rule of thumb i discovered is if it has a 9 following he letter then it has 3.54 gears and if it has a 5 then it has 4.10s
Old Sep 21, 2004 | 05:56 AM
82F100SWB's Avatar
82F100SWB
Don't have a listing here for 37, but, 33(van specific axle code) is a Dana axle of 6540# capacity with 3.54 gears.
Old Sep 21, 2004 | 06:28 AM
bremen242's Avatar
bremen242
best thing is to buy something from the ford parts, then tell the guy to look up the code
Old Sep 21, 2004 | 03:21 PM
mustange70's Avatar
mustange70
Thanks, it seemed when i drove the van it seemd like 3.30's, but maybe thats because the motor is dogged out.
Old Oct 12, 2004 | 12:27 PM
dnelmo's Avatar
dnelmo
Good afternoon:
You have the same axle code I have on my '80 F-250. It is a 3.54, 5300lb Dana axle. I located a pretty good VIN decoder at the following link:
http://4wheeldrive.about.com/gi/dyna...rm%2Fbronco%2F
Select Ford VIN decoder (left side of screen)
David
FordF100man
Nov 7, 2015 01:52 PM
FordF100man
Offroad & 4x4
Oct 29, 2015 08:27 PM
Grappler150
178
Mar 21, 2015 07:22 PM
nyphan21236
Apr 5, 2014 04:57 PM
speedfreak78
Nov 30, 2010 02:28 PM
