Shifter Indicator Problems
Old Sep 19, 2004 | 08:07 PM
bigorr's Avatar
bigorr
I recently had a problem with my 87 F150 replaced a lot of parts (elect) I have everything together but now the shifter indictor shows the truck is in 1st when it it is in Park. I replaced the ignition swith oon top of the steering column. How do I line up the switch with the rod.
Old Sep 20, 2004 | 01:12 PM
Demian's Avatar
Demian
If I remember correctly, there is a set screw on top of the column, kinda to the left side. You can loosen that and move the indicator, on a wire, to the correct place, then tighten that screw up.
