351W running hot
I used the distributor out of the old engine.
I used the 2bbl off the old engine along with an adapter just to get it usable until I get around to rebuilding a 4bbl.
Timing set to 86 specs.
I used the old exhaust manifolds.
No vacuum leaks.
Set up as a very basic engine, all extraneous EPA lines removed, plugged, etc.
Radiator appears to be flowing OK but I havent tested it; never any problems with the old engine. Thermostat is a new 180 deg and works fine. Tried different clutch fans including known good one off my 83 F150/351W.
Heating doesnt show up at idle, just when Im doing heavy loading up and down hills. Got about 4000 lbs in the back.
Ive a few ideas I want to run past you guys as well as troll for some more.
1. Distributor curved wrong for new engine.
2. 2bbl and adapter causing a lean condition.
