Sponsored by: Auxito
03 Screw pulls right,now what?
Old Sep 18, 2004 | 05:54 PM
Lund50's Avatar
Lund50
Hi,I'm not much of a mechanic,so what do I do about my truck pulling to the right?I just got back from a trip with it,about half way back I noticed it wanted to pull right.I checked the right front tire and the tread seems to be cupped on the outer side.Do I need an alignment or is it something else?Also,down the road when I need tires,will 265/16s work?I have 255/70/16 on now.Thanks for any help,Joe
Old Sep 18, 2004 | 06:14 PM
AegisSailor's Avatar
AegisSailor
An alignment will probably cure your pull to the right.
Old Sep 18, 2004 | 07:30 PM
bosshoss's Avatar
bosshoss
Might need to have the wheel alignment checked, also you might have a tire causeing it to pull. Try switching the front tires from the left side to right side, and right side to left side see what happens. Good luck
Dave P.
Old Sep 20, 2004 | 10:18 PM
mgsalida's Avatar
mgsalida
Smile 265/16
Hi Lund
265/16's should be ok on your rig. I have an 03 S-Screw and it has 265/16's on it. So far, no trouble. Good luck
