Changed my plugs
Old Sep 18, 2004 | 04:36 PM
TDean's Avatar
TDean
Changed my plugs
All of them looked normal except #8. It was wet with oil and black of course. The other seven were white and appeared normal. I read on this forum quite some time ago that it was pvc or vacuum related. Cant really remember. Can someone shed some light on this for me again. For a 93 f150 351 it still runs quite well. However, it could run a little better.
Thanks
Old Sep 18, 2004 | 05:52 PM
EPNCSU2006's Avatar
EPNCSU2006
Yes, do a search for "PCV re-route." It is a common problem for these trucks.
Old Sep 18, 2004 | 05:57 PM
Egor's Avatar
Egor
The PCV hooks right into the back of the upper intake manifold, causing most of the oil and gases to dump into the #8 cylinder. You can go buy a longer hose and a plastic T and move it to the center of the upper intake. There probably won't be a spare nipple there for it, so use the plastic tee and hook into the line that runs to the brake booster.
Old Sep 18, 2004 | 06:59 PM
TDean's Avatar
TDean
Thumbs up
Thanks guys!! I'm back on track. Stayed away to long.
