Swaping out
Old Sep 18, 2004 | 08:27 AM
yomow's Avatar
yomow
Swaping out
Hi, guy's I'm getting ready to rebuild & swap out my old trany Cruse-O-Matic, to a C-6 do I have a lot of mods. to do or is it a straight up job. It now has a 352 w/ 390crank & rods .030 bore & headers . Will the cross - member work???
Thank's for the Info., Don Cross
Old Sep 20, 2004 | 10:15 AM
Mike G's Avatar
Mike G
I believe they will work for you, you may need to move it around on the frame, back or forth, to get it to work correctly. Do you have a new torque converter for the C6, may need one of those...
--Mike
Old Sep 20, 2004 | 12:25 PM
85e150's Avatar
85e150
Remember to check the shift quadrant:
Old autos use P R N . D L
Where the . was a 2nd gear start and held second.
New is P R N D 2 1
So if you drive in D but have the new tranny you are alway is second.
You'll figure this out listening the the shifts....
Old Sep 20, 2004 | 07:25 PM
Customcab's Avatar
Customcab
I replace my C-4 with a C-6 recently; the only suggestion I could recommend is to ensure that the clearance at the fire wall is enough; I place my engine/trans combo swap alittle to far back. For when I needed to remove only my transmission I had to pull my engine as well.
I did a 300cid & C-4 swap to a 302 & C-6 combo.
Mitch
