Temp. Control not Working
Old Sep 18, 2004 | 07:20 AM
AT6AERO's Avatar
AT6AERO
The temperature control **** on my 99 F150 is not working. The **** will turn 360 degrees with no change in heat/cold. Any ideas on a fix?
Old Sep 18, 2004 | 04:58 PM
ms_michelle's Avatar
ms_michelle
Check to see if the vacuum line is off of the back of it. Also check for any other vacuum leaks you may have in the system.
Michelle
Old Sep 19, 2004 | 01:56 PM
Racerguy's Avatar
Racerguy
Also check the **** itself. They break quite easily and then just spin on the shaft.
Old Sep 19, 2004 | 07:38 PM
AT6AERO's Avatar
AT6AERO
Racerguy, who would have thunk it. The **** was cracked. Couldn't detect it at first. Problem solved.
Old Sep 19, 2004 | 07:45 PM
Racerguy's Avatar
Racerguy
Good to hear
Old Sep 19, 2004 | 07:46 PM
ms_michelle
Thumbs up
RacerGuy, that was pretty good trouble shooting, you was dead on the money on that one.
Michelle
