Sponsored by: Kumho
Rear Shock Mounts
Old Sep 18, 2004 | 07:15 AM
Motoshrump's Avatar
Motoshrump
Rear Shock Mounts
I just installed a set of Edelbrock IAS shocks on my 93 2wd (5.0) I ordered the rear shocks for a 4x4 truck( could have swore they are the same as the 2wd) however the travel is the same but the shock body is about 3" loger and when the truck is on the ground the shock is at around 2/3 of its travel. Is there a difference in rear upper shock mounts between the 2wd and 4x4 drivetrains? Any help would be a appreciated
Old Sep 18, 2004 | 08:31 PM
rhodie's Avatar
rhodie
Probably the shock mounts are the same; but a 4x4 will have 2 inch spacer blocks on the springs to raise the rear so it's more in line with the increased height up front.
