tint
The trucks cordial red paint, so black tint should work.
Doenst look that hard, ... but....
also, does black really kill the heat? If so, i'll happyly get a windshield cover, found a cool one thats retractable at wally world.. If not, would the Rv silver stuff be better? would it still retain the bling-bling look?
By the way, im in ontario... ne1 know the laws?
thnx for any input..
http://www.courage.ca/services/autotintlaws.htm
If you decide to do it anyway, I would recommend precut tint. Clean your windows inside and out. Put a few drops of dishwashing liquid in a spray bottle with water and soak the window. Peel the backing off, making sure the tint doesn't wrinkle. Soak the back of the tint. Stick it on the window. Use a squeeqee to remove all bubbles and excess water. Sounds a lot easier than it actually is.
