Rust
Old Sep 18, 2004 | 02:38 AM
Garland's Avatar
Garland
Rust
After a much better inspection of the underside of my truck, everything seems to be covered in flakes of rust. The frame rails, bed bottom, shock mounts, etc. Is it possible to do anything about this or should I go looking for a truck in better condition to pour my money into?
Old Sep 18, 2004 | 08:07 AM
Beast12's Avatar
Beast12
My truck is the same way. It is mostly just surface rust. You can probably just scrape it off and you will be down to the frame again.
-Matt
Old Sep 18, 2004 | 04:53 PM
85F_150driver's Avatar
85F_150driver
best way to get rid of it if its not to bad would be to scrape the flakes off and sand or wire wheel down to shiney bare metal then either undercoat it or spray it with a rust inhibiting paint. Mine is like that too but i havent gone anything with it yet in 3 years and it hasnt gotten any worse yet that i can tell lol. If you want a different truck i know of a couple around here for 500 a piece.
Old Sep 19, 2004 | 12:49 AM
mustange70's Avatar
mustange70
If you want to keep the rear fenders from rusting out cut out the rear inner fenders that goes between the wheel well and and the outer fenders
