Destroke The 300
Yea, it's lots of work and expense....
And then you have the valve train.
And then I'd say you are probably going to be limited to 5000 or so due to the other limitations of the engine.
Have you heard of the 302 V8?
Just a suggestion......
.1 the 300 redlines a little above 5 grand, which isnt ideal for a racing application, 2 the 300 probobly wont fit in a car, it might i dont know, 3 with all that work you'll be on welfare,4 it would be better if you dropped a 302 in there, lower the compression to about 7:1, then put a SUPERcharger on there and run tons and tons of boost
with that you would eat toyotas and **** hondas. plus i'd imagine the 300 having a long stroke, wich also isnt good for horsepower
. Stroke is 3.180.4.020": 242
4.030": ~243
4.050": ~246 and pushing things a little
4.060": 247 and possible grenade...
Looking at all of this, you might be less in the hole with a normally-aspirated 351W. Less part$ to throw at 'er for desired power output, and it might fit a little better. I don't mean to sound discouraging---hey, if you have the money and the wherewithal to bite this off, by all means go for it! However, there are considerably more cost-effective methods available.
A low-boost, moderate RPM 300 might even be such a plan, but still, it's severe duty valve, copper reinforced head gasket, ARP rod and main bolts and head studs, forged piston, deck+head shaving, and balancing time. And a carb or EFI set up for the fuel demands of the turbo, and a boost timing retard. Et cetera. The list goes on...
