Aerostar Ford Aerostar
87 3.0 OIL LEVEL SENSOR
Old Jul 14, 2000 | 11:36 AM
fiftynine's Avatar
fiftynine
Just wondering if any one has replaced one of these.Ineed to replace mine and not sure how its done.hopefully wont hve to pull the oil pan off again.thanks in advance for any tips or suggestions.
Old Jul 15, 2000 | 05:51 PM
Phillip Guidry's Avatar
Phillip Guidry
From what I can remember, the sensor itself is held into the oil pan cavity by a simple wire clip that can be easily dislodged from it's retaining groove. Once the retaining clip is off, simply slide the sensor out of the cavity and replace with a new one. The new sensor should have a new o-ring mounted all ready on it. If you are trying to stop an oil leak, you may need just a new o-ring for the sensor. But, most of the oil leaks are from the adapter that is screwed into the oil pan to house the sensor itself. I'm not sure if the adapter seal/gasket is replaceable on the vehicle,so, a good look at the breakdown at the dealership will clew you in as to whether or not you can replace that seal without oil pan removal.
Phillip
Old Jul 17, 2000 | 09:39 AM
turbobill's Avatar
turbobill
