Oil Dripping!!!
Old Sep 17, 2004 | 05:36 PM
444dieselrod's Avatar
444dieselrod
Question Oil Dripping!!!
I guess I am finally sick of my truck dripping oil and I wanna fix it.
from what I have read in here, I think it is the turbo pedistal O-rings or the EBPV leaking. there is constanly oil on the back of the engine and it only drips for about 15 minutes after shutdown. I can't really tell which one it is but I was just curious as to how hard either of these are to fix, once I finally figure out which one it is.
"Any input is good input"
Diesel rod
Old Sep 17, 2004 | 07:56 PM
DavidHaile's Avatar
DavidHaile
If you are still under warranty, take the truck to Ford and let them deal with it!
It is likely the turbo pedestal bolts are loose and/or the o-rings need to be replaced. I haven't done it (dealer did it), but I understand that only access to that part of the engine compartment is the difficult part of the job.
Mine looked like the rear main seal was leaking. It wasn't.
--Update---
Whoops - just looked at your Gallery. You have a 1997 - not under warranty. Now I'm not sure that what I said is true for your engine.
Old Sep 17, 2004 | 09:05 PM
ltfox's Avatar
ltfox
Check out your high pressure fuel rail plugs at the back of your heads. They are notorious for leaking. It could appear to be a turbo leak espc. if its on the drivers side.
Old Sep 17, 2004 | 09:20 PM
HeatStroked's Avatar
HeatStroked
My Wicked Wheel/ "O" ring replacement instructions can be found HERE . Just ignore the wheel instructions and everything you need to know for the turbo and pedestal "O" ring replacement are included.
Old Sep 18, 2004 | 03:01 PM
444dieselrod
Thanks Heat.
Lots of good pics and info.
Diesel rod
