Fuel Delivery
Old Sep 17, 2004 | 04:09 PM
Gregg C.'s Avatar
Gregg C.
Question Fuel Delivery
One of the trucks I own is a '79 F-350 Lariat Supercab 4x4. It has a 400 ci engine and dual fuel tanks. The problem, When I switch from the rear fuel tank to the front, the guage immediately goes to empty. The truck will still feed and run off of the rear tank. Any ideas what the cause is? Thanks for any help.
Old Sep 17, 2004 | 06:54 PM
dennisinmo's Avatar
dennisinmo
I don't have a truck with dual tanks but I would guess you have a wire off the sending unit that doesn't work or off of the switch. Also could be a bad ground on the tank that does not work. Good luck
Old Sep 22, 2004 | 04:39 PM
Bookman's Avatar
Bookman
71 F 250 duals if I din't get the manual switch to click into the exact spot it won't read on the gauge. A little adjusting will get it to read.
Old Sep 22, 2004 | 05:37 PM
Gregg C.'s Avatar
Gregg C.
Thank You guys. I will do some checking this weekend and see what I come up with.
