I do know that all the early 80's trucks used the same cab and mounting points. I just put an 81 F150 cab onto an 83 F250 and had no problems moving all the 250 stuff over. Should be the same for the '72
Thanks, When I go back I am going to offer to remove it myself and see if they will take $50. It also has the metal door panels they want $20 for the pair and I need to replace my original cardboard ones.
Well, I got the booster and bracket from the 250 and it looks like the bracket will bolt up. But, the bracket has a lever built in that has a flat piece of steel that goes into the fire wall and bolts to the brake pedal. The master cylinder is larger than my stock mc. The pictures in the shop manual show a rod coming off the back of the booster and going direct to the brake pedal. This one, the rod connects to the lever system on the bracket.
Will all this work? Do I need the brake pedal from the donor truck also?
Or, will I be better off finding the right set up for my F100?
Yes it will work, there were two styles of boosters. One has the rod and the other has the lever that you've got. I'd grab the pedal too, there is a difference but I can't remember exactly what it was right now. It was either the pin location and/or the brake light. I have both style boosters:
Well, I went to Auto Zone and ordered the MC/Booster set for a 72 F250 without adjustable rod. The one that came had a rod from the booster that was about a foot or more long. Way to long to bolt to the firewall bracket. So I took it back and ordered the one with adjustable rod, it came back with a rod that had a screw nut on the end rather than the eye that I need to hook up to the bracket with lever.
Does anyone have any part numbers, Auto Zone can't seem to find the right one. Mine looks just like the larger one in the picture in the earlier post. Getting frustrated and beginning to think someone had changed the one on the donor truck I used.
Well, turns out this 72 was made late in production year and a 73 is what fits. Cardone part # 50-3009, good at Auto Zone, NAPA or Oreilly - $99 with core.
