New Wheels & Tires==== new shimmy!!!
Ok,,, this is driving me crazy... I put about 37,000 miles on my factory wheels and tires,,(they were the 18's). I've got the 04 xcab fx4 with the 5.4l. I did the leveler kit, body lift,,, 18x10 wheels, and nitto terra grapler 325x65x18" tires. At about 50 to 60 the steering wheel shakes,,, sometimes more than others... They've changed out my wheels once,,, they still do it... The new wheels and tires balance out at zero and everything,,, but it won't go away,,, We put the factory wheels and tires on just to see if it had anything to do with the lift or leveler, but then the shakes gone,,,, Are these tires too big for this front end or what? I need help,,,
thanks,
Chris
thanks,
Chris
Your tires can be be balanced to death, but if they are not round you'll never cure the problem. The bigger tires are tougher it is to make them round and they will also get out of round easier and faster. I've gone through this 6-8 times in the last 25 years putting bigger rubber under trucks. When they are new get them checked and replaced. When they get that way over time the only thing you can do it get them cut round. They do it to tractor trailer tires all the time..
