EFI to Carbureted
Old Sep 17, 2004 | 12:20 PM
White Goat's Avatar
White Goat
Question EFI to Carbureted
What would it take to change a 351w EFI to carbureted?
Old Sep 17, 2004 | 12:24 PM
White Goat's Avatar
White Goat
Thumbs up Found the answer on down..
Should have looked longer before posting. Thanks anyway!
Old Sep 17, 2004 | 12:29 PM
jwtaylor's Avatar
jwtaylor
Intake manifold
carb
distributor
possibly a distributor coil...definitely a module...or you could get a one wire hei distributor for fords, they have everything built in to one unit.
either use a fuel pressur regulator to get your fuel psi down to 6 or electrically unhook, your stock efi pumps and install an electric fuel pump for carbs somewhere inline of the fuel line
Need to get a throttle linkage out of a carbed truck.
If its a automatic tranny now computer controlled then you would need a stand alone unit to operate the tranny (contact a tranny company), if its a standard tranny then your good.
later
Old Sep 17, 2004 | 10:16 PM
MustangGT221's Avatar
MustangGT221
I wouldn't bother...EFI is very good.
