Aerostar Ford Aerostar
Upper Control Arm Bush Replacement
Old Jan 27, 2000 | 04:26 PM
Phillip Guidry's Avatar
Phillip Guidry
Old Aug 13, 2000 | 04:12 PM
Phillip Guidry
Just wondering if anyone has replaced the upper control arm bushings on a "89-like Aerostar ? Luckily the upper bracket is a 2 peice design,so I can just deal with the rear bushing on the passenger side,which is the only one that is bad,for some reason. I was wondering how tight the thru bolts for the bracket would be,should I just get the 3/4 impact ready or will a 1/2 breaker bar do just fine ?
Thanks in advance
Old Oct 16, 2000 | 03:59 PM
cfp12's Avatar
cfp12
>bar do just fine ?
>Thanks in advance
I just changed them on my 93... no problem with 1/2 inch stuff. Just be sure to get them torqued back down to the proper spec. Those bolts hold the whole "a" frame as I recall.
