Fuel system Help needed
Old Sep 17, 2004 | 04:03 AM
yj bill's Avatar
yj bill
I have a 1985 Ford E350 motorhome chassis with a carburated 460. The in-tank electric fuel pumps will run only when the start circuit is energized (key in start position with starter engaged). Starts and runs for 10 or 15 seconds untill the float bowls are drained. I have changed the ignition switch and the fuel pump relay with no positive results. Any advice will be much appreciated.
Old Sep 17, 2004 | 06:03 AM
82F100SWB's Avatar
82F100SWB
There is an inertia switch in the hot in run circut(not a clue where it'd be in a Van) and an oil pressure switch(located on the block behind the intake.) One of those two could well be the culprit.
Old Sep 17, 2004 | 09:48 AM
yj bill's Avatar
yj bill
Thanks, 82F, bad connection on the oil psi switch, really easy fix!
