Door Adjustment
Old Sep 17, 2004 | 12:24 AM
Digger6's Avatar
Digger6
Door Adjustment
I would like to here any tricks for adjusting the doors on my '90 1/2 ton.
Old Sep 17, 2004 | 01:20 AM
andym's Avatar
andym
I think you're going to have to elaborate a little bit.
Old Sep 17, 2004 | 08:58 AM
5_labsownus's Avatar
5_labsownus
If the door sags or is not hitting the striker post correctly? The hinge bushings are bad and need replaced. If you have replaced the bushings or replaced a door and need to line it up? It is best to pay a good body shop to adjust the door. It is trial and error for most of us non-body shop people!
Old Sep 17, 2004 | 12:57 PM
FordPerf300's Avatar
FordPerf300
eastwood sells a door alignment tool. loosen bolts, hook it on the the latch and the door and use a breaker bar to twist it back up and tighten bolts.
Old Sep 17, 2004 | 05:08 PM
91f250460's Avatar
91f250460
Put washers between the bottom of the hinges and the door frame. Adjust number of washers accordingly until door lines up properly. As mentioned the bushings are bad, but the washer trick works just fine and is free.
T. Roberts
UFD Local 1147
Old Sep 17, 2004 | 05:36 PM
couleeman's Avatar
couleeman
Washers work pretty good. I have done that on several vehicles.
Old Sep 21, 2004 | 02:29 PM
Digger6's Avatar
Digger6
Thankyou for the responses to my question. I tried to alinge it myself, but couldnt get it. took it to a body shop much less headaches.
