Brake Light
Old Sep 16, 2004 | 11:44 PM
69highboy's Avatar
69highboy
Question Brake Light
Just a quick question, what trips the brake light on the lower
left of the dash? Does It go to the prop valve or Is there a
switch that I'm missing? I have a 4x4 that has It and a 2wd
that has the lens and no wiring or bulb, what gives?
Old Sep 17, 2004 | 12:31 AM
Jimbare's Avatar
Jimbare
all alone in the world
i think that is the indicator for the emergency brake only.
Old Sep 17, 2004 | 12:07 PM
Freightrain's Avatar
Freightrain
Mine was alwas wired to proportioning valve. If you blow a line, it would light up because the valve would trip one way or the other.
I think most of the time the valve gets stuck and won't work.
Old Sep 17, 2004 | 12:09 PM
pfogle's Avatar
pfogle
It could be in the proportioning valve, or on the master cyl iteself. There is also a switch on the e-brake.
Old Sep 17, 2004 | 12:32 PM
user 5363849's Avatar
user 5363849
I've been wondering this one too. There's no switch on my emergency brake.
A few days ago, I was changing the turnsignal switch on my 71 F-100. I still have the wiring diagram out, and I'll try and take a look.
Mine's on too, and I've never known why.
(Yes, I know about the proportioning valve, but I've never bothered to check to see if that's it...)
Old Sep 17, 2004 | 03:01 PM
Freightrain
Back when I had my '70 F100, I unplugged the sender at the pro. valve. Kept the light out. I would guess the sender had failed/stuck and kept the light on.
Old Sep 17, 2004 | 03:31 PM
BB's Avatar
BB
Emergency brake doesn't have a light or switch. There's a pressure differential valve that lights the brake light if the front or rear half of the hydraulic system fails.
See:
https://www.ford-trucks.com/forums/s...hreadid=102575
Old Nov 21, 2004 | 09:35 PM
1968 F250camper's Avatar
1968 F250camper
I have the same issue as well on my '68 F250 with dual caliper disc brakes in front. They have been leaking brake fluid recently, as have the rears on the passenger side of the truck. The leaking seemed to coincide with that brake light going on. I have not been able to find a switch either to see if it was stuck on. I guess I will try to find the proportioning valve to see if there is a wire/switch there. Better yet, I guess it may also be telling me to GET THE BRAKES FIXED!!!!!
Old Nov 24, 2004 | 06:53 PM
mouse777's Avatar
mouse777
BB is correct. If front or rear brakes fail, get low on fluid, etc, the lite comes on.
Old Mar 28, 2005 | 10:21 PM
greightscott's Avatar
greightscott
Question
I read on the forum about 18 monhths ago. There "IS" a way to clear that light. Does anyone know how?
Old Mar 28, 2005 | 10:27 PM
BB's Avatar
BB
It's in the link I posted.
