Sponsored by: Real Truck
Straight piped
Old Sep 16, 2004 | 08:11 PM
johndo's Avatar
johndo
Straight piped
I was wondering, I was going to take my stock exhaust off to replace it with a flows. I was going to take off the cat and muffler and was wondering would it hurt the truck at all to run it with no cat and muffler for a little bit just to see what it sounds like? Curiosity killed the cat to many times. Thanks, john.
Old Sep 16, 2004 | 08:27 PM
RealMenPowerstroke!'s Avatar
RealMenPowerstroke!
Hey Bubba,
Need some more info on your truck.. Mostly just the engine, also the miles, and state you live in, also perhaps you driving habits..
Best of Luck,
Corey
*Parts Changers*
Old Sep 16, 2004 | 09:13 PM
johndo's Avatar
johndo
Your absolutely right, I completely forgot the truck specs, my fault. I have a 2001 F250 reg cab, 8ft bed with a 5.4L Triton, its 4x4 and I live in Maryland. I am pretty light on the gas most of the time, but can get on it now and then.
Old Sep 16, 2004 | 09:49 PM
farmb0y's Avatar
farmb0y
Removing the cat and muffler shouldn't hurt your truck at all, it will make it noisy though!!
Old Sep 17, 2004 | 09:15 AM
01f350's Avatar
01f350
It won't hurt your truck, but many peolpe say that an engine needs back pressure to run properly and not having a muffler eliminates all back pressure.
It will definitely be LOUD.
Old Sep 17, 2004 | 09:29 AM
warmdye's Avatar
warmdye
ya it won't hurt it, you will lose some low end though. You'll gain more in hps.
Old Sep 17, 2004 | 10:12 AM
farmb0y's Avatar
farmb0y
Four strokes don't need back pressure to run properly, two strokes do. Take a look at all the high performance engines: nascar, drag cars, anything of the similar, none of them have any exhaust except headers just to direct the exhaust away from the driver.
Old Sep 17, 2004 | 10:31 AM
iskybantilus's Avatar
iskybantilus
yea ... nascar definatly has pipes, you'll notice the two of them exiting same side, passenger side, right where the back of the door would be. tuning the size of those pipes is used to attain peak horspower. you are also talking about a car that runs at maximum rpm (8,000 plus) for a few hours straight, torque down low isnt really necesary like when you drive anything on the street.
you dont need an excess of backpressure, what you need is a flow, to big an exhaust and you loose that flow. a constant smooth flow of exhaust will create a suction to scavage exhuast gases from each cylinder as is opens up for expulsion of exhaust gas. too much backpressure, and the engine has to work to force this exhaust out (hence the power gains of a high flow exhaust), too little flow ... aka 6 inch exhaust on a 4 cylinder, and you could cap it off for a while and it wouldnt make a difference, there is no flow velocity.
in summary, that exhaust velocity creates the smooth constant flow which promotes the most power, the size of the exhaust will affect at what rpm your peak gains are.
Old Sep 17, 2004 | 08:47 PM
f-4x4's Avatar
f-4x4
if you dont put a piece of pipe in place of the cat and muffler it will make your valves warp. but what do i know im just a 16 year old
Old Sep 18, 2004 | 04:32 PM
RIS's Avatar
RIS
I've got an 01 5.4L CC LB 4X4 250 and I'm running 2" dauls from the sensers back with large flows & 18" tips. NO CATS! The first 3 days with the new pipes it had some little nothing flows and I cuoldn't stand the noise. Couldn't talk on my cell!
Look at the Y pipe . It is Cremped down to about an inch. Thats why I did it. Picked up about 2 MPG. & it looks good!
