Aerostar Ford Aerostar
Wheel Bearings
Old Jan 8, 2001 | 11:34 PM
aerostar driver's Avatar
aerostar driver
Wheel Bearings
I am an owner of a 91 Aerostar short one 2 whell drive and have had problems whith right front outer wheel bearings goeing bad. I think I will have to replace the brake roter and Spindle assy any other suggestions. Also would it be too diffucult in swapping my 3.0 ltr for a 4.0 ltr. the eng has 160,000 on it and getting tired. Thanks Kevin
Old Jan 9, 2001 | 11:48 AM
MarkP's Avatar
MarkP
Wheel Bearings
If the hub is damaged where the bearing(s) outer shells press in, it will have to be replace also. Hopefully not though.
Often the spindle can be cleaned up and the damaged area touched up with emery paper if not too bad. The bearing inner races are slip fit.
-Mark Paar
> I am an owner of
>I think I will have
>my 3.0 ltr for a
>4.0 ltr. the eng
Old Jan 12, 2001 | 08:54 AM
aerostar driver
Wheel Bearings
I changed the brake roter and shaft assy. seams to be alot better now it wasnt that bad to chang one of the easier things to chang on this van! Any body heard of swapping a 3 ltr with a 4 ltr and maybe the supercharged v-6 from a t bird? thanks all Kevin
Old Jan 12, 2001 | 10:13 PM
old fool's Avatar
old fool
Wheel Bearings
