Aerostar Ford Aerostar
A/C compressor rattles
Old Jan 12, 2001 | 02:43 AM
tomucen's Avatar
tomucen
The A/C compressor on my '93 3.0L developed a rattling sound. I first thought the chain was loose but then tracked it down to the compressor. It has a light rattle when the engine is running. The rattle gets much stronger when the compressor clutch engages.
Has anybody had this problem before? Am I looking at having to replace the compressor soon? Actual mileage is 78K.
Thanks for any input.
Tom Ucen
1993 Aerostar XL Ext. 3.0L
Old Jan 12, 2001 | 09:16 PM
deleontow's Avatar
deleontow
Remove the belt and with your hand spin the pulley, not the compressor hub, see if you feel any abnormal movement on the bearing, you may just need a pulley bearing, which could be changed without removing the comrpeesor
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Jan 12, 2001 | 10:00 PM
old fool's Avatar
old fool
Ford had a fix for this problem. Ask your dealer to look for a TSB on this concern. Something with the idler pulley I think. They will be able to fix it, but it's not a recall so it will cost you.
Old Jan 15, 2001 | 02:39 AM
tomucen's Avatar
tomucen
Thanks a lot, guys! I will take a close look at the pulley. Unfortunately, Ford won't help me because Aerostars were never officially sold in Europe.
Tom Ucen
Munich, Germany
Old Jan 18, 2001 | 03:11 PM
turbobill's Avatar
turbobill
