Ground Wire...or somthing else??
Old Sep 16, 2004 | 09:03 AM
Rednels's Avatar
Rednels
i have an '01 powerstroke and yesterday it was having an electrical problem. I slammed on the brakes to avoid someone and all power to the intrument cluster was lost.
It is pretty random on when it happens but it seems to happen with the turn signals are used or head light switch.
is this a ground issue? if so, where should i look for the ground wire?
thanks,
Eddie
Old Sep 16, 2004 | 09:55 AM
Foneguy's Avatar
Foneguy
I have a problem with my headlight switch as well... I haven't spent much time with it yet Mostly cause they still work. But mine are now out alltogether except for the Fog light part. Anyone have any suggestions on this?
Thanks for starting this one Rednels..
Thanks
Foneguy
Old Sep 16, 2004 | 10:27 AM
cgl's Avatar
cgl
Originally Posted by Rednels
... all power to the intrument cluster was lost.....
Meaning that the gauges aren't working? I know that on my 02, the gauges, radio circuit, power windows, and the dome light circuit are all powered off of the same fuse. I believe the fuse powers up the individual relays.
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2001 400ex SportTrax
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
Old Sep 16, 2004 | 10:47 AM
Rednels's Avatar
Rednels
Well today when i turned on the turn signal and hit the brakes the radio went off. all power was lost, as if turning off the ignition, but the engine did not die.....weird
Old Sep 27, 2004 | 02:05 AM
CAPITALIST PIG's Avatar
CAPITALIST PIG
maybe a bad foot pedal brake switch...did you ever get a clicking through the radio before when you applied the brakes..HHHMMM maybe. good luck
