Aerostar Ford Aerostar
MERCON V
Old Feb 5, 2001 | 07:07 PM
eg0168's Avatar
eg0168
MERCON V
is MERCON V safe for 89 aerostar? I noticed a difference
when im using this oil, the tranny is slow to react in city driving but great in the freeway. Or could it be the 3-4 solenoid that i replaced which is a little bit tight/fits just right on the valve. (old one is kinda loose)
thanks for your input...
Old Feb 8, 2001 | 02:31 PM
Mikeman's Avatar
Mikeman
MERCON V
[font size="1" color="#FF0000"]LAST EDITED ON 08-Feb-01 AT 03:36 PM (EST)[/font][p]Yes, you can, at least in the case of Valvoline's Durablend ATF (but I would imagine it's the same regardless of who makes MERCON V). It's similar to how you can run SJ oil in an engine the specifies SD but you can't go the other way. You can check Valvoline's website, go to the ATF category and pick their Durablend product
http://www.valvoline.com/index_products.html
Old Feb 13, 2001 | 02:57 PM
gunner17's Avatar
gunner17
MERCON V
