1988 F250 differential
I was wondering the history of this differential. It is a 1988 f250 with the 460 and a c6. When we got the truck in feb or so it was working well, or so we thought--- In June we noticed a clunking sound coming from the rear end which was soon to be diagnosed as the bolt that goes to the center pin sheared which complety destroyed the carrier,ringh and pinion, everything inside except the axles. So after we spent alot of money to get it fixed about 3 weeks later the bolt broke again so it was repaired under the shop warranty. A couple of days ago it made that same infamous noise, so it was towed back to the shop and diagnosed as the bolt sheared off again. Has anyone ever had a problem with that rear end or is there a way to make it better?
Thanks alot Joey
Thanks alot Joey
89nolaf250
47
03-08-2010 12:41 PM
Wyof250
09-28-2006 07:56 AM
stallion 460
07-12-2005 11:03 AM
