rear end blues
Old Sep 15, 2004 | 06:06 PM
bluesbro19's Avatar
bluesbro19
Thumbs up rear end blues
I have a 66 flareside pu,with a 8",3.50 gear ratio rear end,,its ford model not dana,does anyone have a diagram?I got it in peices & need to see how it goes back.All I really need is the front pinion & gear info,like torque on the crush washer etc.I could use some help.
Last edited by bluesbro19; Sep 15, 2004 at 06:09 PM. Reason: didnt give info right lol
Old Sep 15, 2004 | 06:48 PM
85e150's Avatar
85e150
You most likely have a 9 inch. Similar to the 8 inch but a bit stronger.
Since I don't like howler diffs, I'd steer you to a dealer or shop where the guy can show you he knows how to do this and will guarantee the reassembly.
A Ford shop manual will have the specs.
Haynes has nothing.
You have to set the depth of the pinion into the ring.
Set the gear pattern.
Set the lash.
Crush the crush collar to a specified torque to properly load one of the bearings.
YOU need:
Dial indicator, stack of shims, torque wrench that goes to 150+ lb-ft. & a
Man-size vise to hold the carrier whilst you ply your craft. And that little bottel of white paint to check the pattern with.
Call me silly. (as others have) but I would "leave it to the professionals".
Especially if you've paid good money for new gears and bearings etc.
I watched a Ford guy rebuild my 8 inch, so that's how I became such a know-it-all.
Good luck,
Old Sep 15, 2004 | 06:50 PM
cdherman's Avatar
cdherman
An 8" in a 66? Like, who did that? Should have a 9" from the factory.
In the case of a nine, you need to do a lot more than just torque things down. Need to adjust the lash and get preload set right. I know there are video's being sold on ebay all the time that purport to tell the novice how to do it correctly. The instruction in my ford shop manual are pretty complicated if you ask me.
I don't have a scanner handly to make copies of my ford manual, and I cannot say that I would recomend it anyhow. Maybe ought to clarify what you have for sure first.
Old Sep 16, 2004 | 07:45 AM
Tiremine's Avatar
Tiremine
bluesbro19
Check out this sight. If it is a 9 inch this is all you need.
http://www.fnc.ch/Technik/9-Inch_rebuild.htm
If its an 8 inch maybe someone out there knows of a similar sight for them
Good luck
Old Sep 16, 2004 | 08:00 AM
bluesbro19's Avatar
bluesbro19
Thanks for your help,the tag indicates that it is an 8 inch though,i sure appreciate the replies,,Ilearn somwthing every time.
Old Sep 16, 2004 | 08:57 AM
44dwarf's Avatar
44dwarf
Go over to Randy's ring and pinion site (google the site you find it) he has a tech section with all specs for lots of rears.
44
Jimmiej08
18
Feb 19, 2017 07:23 PM
1963unibody
23
Oct 22, 2015 08:58 PM
dorf1985
Dec 4, 2013 03:51 PM
Richard51
Apr 17, 2013 09:01 AM
BeSee
Mar 24, 2004 09:51 AM
