1978 - 1996 Big Bronco
turn signal issues
Old Sep 15, 2004 | 05:40 PM
igota92bronco's Avatar
igota92bronco
Question turn signal issues
I noticed on my way home that my left turn signal gave out. I tried my right one just to see and it still worked, but when I got home neither of them worked.
Anyone got any ideas whats wrong?
preciate it.
Old Sep 16, 2004 | 12:45 AM
greystreak92's Avatar
greystreak92
First, did the signal quit all together or did it just stop flashing? Two different problems depending on the answer. If the signal just quit, you most likely have a faulty ground to one of the lamps in the signal circuit on that side of the truck. A loose ground will cause intermittant operation for the same reason as described below. If the signal stopped flashing but the lamps still lit, you have a lamp not seated in a socket or a lamp with a broken filament that is reconnecting to the filament support as a result of vibrations in the truck (i.e. going over bumps) on the left side of the truck. Thats the only way to explain the "works/doesn't work" scenario. Check all the lamps that flash with the signal on that side of the truck. Make sure they are making good contact in their sockets (corrosion) and that the filaments are not broken and flopping around inside the lamp.
Old Sep 16, 2004 | 02:07 AM
ANdrewdrice's Avatar
ANdrewdrice
did you check your fluid?
Old Sep 16, 2004 | 09:35 AM
igota92bronco
- (a faulty ground to one of the lamps in the signal circuit on that side of the truck)
where would I find that?? I dont know anything about trucks. I think I am gonna go pick up a manule today, I have a feeling I'm gonna need it quite a bit.
Old Sep 16, 2004 | 06:10 PM
ANdrewdrice
cant go wrong with a haynes or chilton manual
Old Sep 17, 2004 | 09:34 AM
BillyBob69's Avatar
BillyBob69
I know it is rare, but I have had my bulbs go out both sides almost at the same time. Just check those for starters. Then try replacing the flasher relay. Its the little cylinder thing plugged into your fuse panel....About $4 at the parts store. From there, use your new manuals and start tracing back the wiring. Wiring diagrams are a big help.
