Brakes
Old Sep 15, 2004 | 04:14 PM
tazmania18235's Avatar
tazmania18235
Question Brakes
`Driving home from work today my brake pedal just went stiff!!! It will not release the vacuum.. even with engine off pedal is hard as a rock..
I am thinking Power Booster. . Does this sound right?? I have vacuum when I take hose off of booster. How much vacuum should there be??? If I put my finger over the hiose I feel the vacuum. Master cylinder was replaced about 3 momths ago...
Any help would be greatly appreciated
1985 E-359 6.9 Diesel
Old Sep 16, 2004 | 06:10 PM
andym's Avatar
andym
Sounds like your vacuum pump is fine, I'd look at the power booster.
Old Sep 16, 2004 | 07:55 PM
85capr's Avatar
85capr
check the check valve just to make sure its not something stupid before you replace the booster
