Aerostar Ford Aerostar
Power Lock Trouble...
Old Sep 15, 2004 | 02:15 PM
maxwgn's Avatar
maxwgn
As in a previous post, I wrote in that I have just purchased a 1991 Extended van, with power everthing...
The driver-side door-lock does not work. The previous owner took it to the dealership to have it fixed, and they tried replacing the lock solenoid in that door, with no results. He was unaware if they tried a new relay or not.
Does anyone know of any common, quick fix for this?
Where are the lock relays located?
Old Sep 15, 2004 | 03:02 PM
tom_foreman's Avatar
tom_foreman
Are you saying that the switch in the driver's door doesn't work or that when you use either lock button all doors but the driver's locks?
Old Sep 16, 2004 | 12:40 PM
maxwgn's Avatar
maxwgn
It matters not, which we use - the remotes on the keyless entry, the driver's side sitch, or the passenger side switch, all locks EXCEPT the drivers door, operate...
And again, the lock solenoid has been tested good, and was even replaced with a new one, with no results...
Any idea and/or thoughts would be welcome...
I am thinking a possible problem with the relays? Or possibly a problem from the keyless entry installtion (which was a Ford Dealer Installed item.)
Old Sep 16, 2004 | 01:04 PM
cookkd's Avatar
cookkd
Your control lock/unlock relay is located behind the passenger side kick panel.....
Old Sep 16, 2004 | 01:24 PM
psyche's Avatar
psyche
Test solenoid in door by putting 12v on it directly and see if it works. If not, might be bad ground, sticking linkage. If it works, then go for the relays.
Old Sep 16, 2004 | 04:11 PM
tom_foreman
You can also measure for voltage at the solenoid when you hit the lock button and verify power up to that point. If you have it, look at the gound. If not, trace the line back to the relay.
Old Oct 11, 2004 | 07:54 PM
Dave93's Avatar
Dave93
i had this same problem with my 93, i found with my door open the loks worked, what happend was there was a wire that was geting pinched, see if it works when your door is open or in diferent places etc
