03 EB with 38K miles and of course this type of issue would occur shortly after my warranty runs out. Anyway, my driver's seat will move up and down, but not forwards and backwards. I looked around and did not see anything in the track, any other suggestions?
Sounds like a switch problem. Didn't have it happen to the seat but on the outside mirrors. I had a burned contact. Cleaned it up and it works like a champ and all it cost was alittle time. Hope this helps.
I have an 03 eb as well. The same thing happened to my seat 1,000 before my warranty expired. I took it to the dealer and they replaced the whole seat frame.
I had Problems with mine. Same thing. It would go up and down but not foward and backwards. take the switch out and clean the contacts with a nail file. see if that helps. I eventually had to replace the switch.
