Bronco II Ford Bronco II
88 BII bogging need help
Old Sep 15, 2004 | 07:01 AM
turtle_72's Avatar
turtle_72
I have an 88 Bronco II 2.9 automatic. the tranny went out 3 months ago and I just got it rebuilt and installed. The first test drive on the new trany went great. But ever since it has been bogging down and blowing black smoke. I pulled the codes but did not get any help there. I have replaced: idle air control valve, MAP sensor, and fuel pressure regulator with no change. I pulled the plugs and they were black they have been replaced. Could a bad catalytic converter cause any of this. Any help would be great.
Old Sep 15, 2004 | 11:42 AM
87 XLT's Avatar
87 XLT
Take a look i your Haynes manual, it will tell you how to check fuel pressure. Might be a leaking injector.
Old Sep 15, 2004 | 01:29 PM
b2_tim's Avatar
b2_tim
Make sure they re-connected the speed sensor cable to the tranny, or transfer case. Is your engine temp gauge responding normally, maybe a stuck thermostat, or bad PCV valve. If you are getting the normal volume of exhause out the tail pipe skip the bad converter idea for now, there are many other cheaper parts to check first.
Old Sep 15, 2004 | 03:51 PM
Help I M Stuck's Avatar
Help I M Stuck
YES it could.
Old Sep 15, 2004 | 05:54 PM
87 XLT's Avatar
87 XLT
With ALL your plugs burning rich it's strange that you're not at least geting a rich O-2 code. Did you get an 11 code? Hook up a vacuum gauge and do the test for a clogged cat.
Old Sep 15, 2004 | 08:48 PM
Ken00's Avatar
Ken00
Did they pinched the O2 wire between the tranny and engine, very common.
