Sponsored by: Real Truck
wiper question
Old Sep 14, 2004 | 09:30 PM
duckhacker's Avatar
duckhacker
wiper question
Intermitent is non-existent on my 99 250 90% of the time. I have 2 speeds, constant and the high speed. It also doesn't turn off all the time, it will run 2-3 more times before it stops. It will work sometimes for a bit then go to this. Any help/ideas?
Old Sep 14, 2004 | 09:40 PM
n578md's Avatar
n578md
I had the same problem on my 1994. I ended up prying the cap on the end of the wiper stalk and spraying WD-40 in it while switching it back and forth to work it a little. The dielectric grease had broken down and was interfering with the connections. It never acted up again after that.
Old Sep 14, 2004 | 09:41 PM
99f350sd's Avatar
99f350sd
Sounds like it could be the switch..
Old Sep 15, 2004 | 06:03 AM
sulconst2's Avatar
sulconst2
i have a 2000. there was a recall on the switch. dont know if it includes the 99
Old Sep 15, 2004 | 09:18 AM
FordInProgress's Avatar
FordInProgress
http://www.alldata.com/recall/make/F...uper_Duty.html
The recall was for 2000 and up. I don't see one listed for the 1999.
