Checking SCA with Test Strips
Old Sep 14, 2004 | 06:38 PM
Bad Company's Avatar
Bad Company
I purchased the test strips to check my coolant mix. After getting home I realized the radiator on my 95 F250 is sealed. Do I use the test strips in the coolant tank? Will that be as accurate as testing coolant "in" the system?
Thanks in advance for your advice.
Old Sep 14, 2004 | 07:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The degas bottle is the only place you can test it, unless you drain some coolant into a jar. I always just used the degas bottle when I had to test coolant.
Old Sep 15, 2004 | 12:06 PM
Bad Company
Can you explain the "degas" bottle? Is this the coolant tank that sits near the washer fluid tank?
Old Sep 15, 2004 | 03:28 PM
tobetaxfree's Avatar
tobetaxfree
One thing I do is after the system has been circulating for a while, I let it cool a little and suck some out of the "resevoir". It has to be at room temp to test, so I let it sit in the jar. I just want to make sure I am getting a good representative sample.
Old Sep 15, 2004 | 04:47 PM
Bad Company
Thank you. I'll give it a try.
Old Sep 15, 2004 | 05:16 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I have used the degas bottle for mine also. Some have said that they prefer to use the drain for a sample point because the coolant in the degas bottle doesn't circulate well. After doing a coolant change in my 7.3, I was topping off the system with water while the engine was running. I filled the degas bottle with water and within thirty seconds it was green. I think that it flows well enough to use as a test point, IMO.
Old Sep 15, 2004 | 07:14 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep, same same. Coolant tank is what it is "degas" is what it does.
Old Sep 16, 2004 | 05:02 AM
rockyrider's Avatar
rockyrider
Question
I just checked mine for the 1st time, using the strips and my PH was on the high side, about 8.0. How do I correct that?
