c6 shift points
Old Sep 14, 2004 | 05:52 PM
good 'ol ford's Avatar
good 'ol ford
c6 shift points
hey is there a way to adjust the sift points on the c6 tranny with vacume modulator or do u have to put a shift kit in it
Old Sep 14, 2004 | 07:56 PM
fordsrgrt's Avatar
fordsrgrt
pull your vac hose off your modulator and look in there and see if you have a srew head if so turn it by half or full turns will cause it to shift later and much firmer .i believe its clockwise but not sure just try turning it and and then check your shift points
Old Sep 14, 2004 | 10:59 PM
good 'ol ford
i was going to do that but i've herd in the past that it was suposed to be a 1/8 allen screw this looked to be more of a flat screw so i decided not to do it till i had the advice of someone smarter than i. so if anyone has herd of this please tell me if im right or not
Old Sep 15, 2004 | 05:47 PM
good 'ol ford
hey thanx for the help figured it out but now i have a new ? when i pulled off the vac tube oil came out. not much but enough for me to know that it was there is this normal of has anyone even herd of such a thing. if anyone has any idea i would like some advise
Old Sep 16, 2004 | 07:21 AM
jowilker's Avatar
jowilker
Ya got a hole in the diaphram. You'll need to replace the modulator valve.
John
Old Sep 16, 2004 | 09:34 AM
good 'ol ford
well thats what i thought at fist but it was oil not tranny fluid. so i unhooked the the line at the tree and at the vac. mod. and blew it out with and air comp. so i guess we'll see if it comes back or what
