speedometer bounce
Old Sep 14, 2004 | 02:23 PM
1969goat's Avatar
1969goat
Question speedometer bounce
Hello, I have a question. My 1995 f-150 speedometer bounces around. I have changed the sensor in the rear axle and the one in the automatic transmission. My cruise control works, but I cannot use it because the cruise is reading the speedometer and with it bouncing around it speeds up and slows down, very frustrating. Any suggestions greatly appreciated.
Old Sep 14, 2004 | 03:34 PM
georgia04's Avatar
georgia04
Try holding down the reset button while turning the key to the ON position.
It will make the speedometer go from 0 to 85.
Old Sep 14, 2004 | 04:33 PM
brown 4x4's Avatar
brown 4x4
It sounds like the PSOM, or speedometer head, is going bad. It isn't an uncommon problem. Many times they'll also have a glitch giving the computer a false reading at about 1-2 mph killing the engine at that speed.
You'll need to pull the cluster and take each section out, and replace the center speedometer section. One from a junkyard would be the cheapest route, although your odometer won't be the same. Don't worry about finding one with the same transmission or a tach/no tach, they're all the same.
Old Sep 15, 2004 | 02:23 PM
1969goat's Avatar
1969goat
Thanks for the input I will try to look for another dash cluster at a junk yard. I think thats probably the problem.
Old Sep 15, 2004 | 04:32 PM
MustangGT221's Avatar
MustangGT221
Yup, a search for "bad PSOM" will find you the answer.
You can usually have a dealership program the mileage and tire size for you so it's correct. I ended up buying a new cluster from Ford and they programmed my mileage and tire size in it. Same thing happened to me brown4x4 talked about in my other F-150.
