It's back !!
Old Sep 14, 2004 | 11:04 AM
desertracer's Avatar
desertracer
It's back !!
I had the 1750 R. P. M. viberation, Ford said new turbo mount, done that.
Now at 18500 mile it is as bad as when truck was new.
03 F350 2wd build date 1-15-03.
Also still trying to get engine braking back like it was when new
Has enyone else had vibe return,or got braking back ??
Old Sep 14, 2004 | 02:19 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
What happened to that
Old Sep 15, 2004 | 09:47 AM
desertracer
Hi Tim
When new braking was turned on when you engaged tow/haul and worked perfect.
I got a recall to be reflashed for Ca. emissions {dec flash} after the flash braking is
activated by pushing on brake, so hard it is unsafe at times. Braking now {on a 1 to 10} is a 4 at its best. Trying for last 7-8 mos. to get Ford to return my truck to the way I bough it. I do have DSB papers. Can't get Ford factory rep. to even return my calls. I was gone to Ut. for 3 mos. so I feel Ford Has had time to do something.
I must be only one to have 1750 rpm. drone to return. Going to Dealer tomarrow.
Thanks Tim for doing a fine job!!
Old Sep 15, 2004 | 02:44 PM
IB Tim's Avatar
IB Tim
Do not wait for Ford to do something...press on, no news is not good in this case..and thank you!
