Bronco II Ford Bronco II
Rear Brakes
Old Sep 14, 2004 | 08:10 AM
SShank42's Avatar
SShank42
Rear Brakes
The rear brakes will not stay adjusted. I have replaced all the hardware on the rear, still won't stay adjusted. If I adjust them up they are okay for a couple of days then back to nothing. Even had mechanic do the brakes to check my work, same result. Suggestions?
Old Sep 14, 2004 | 08:35 PM
Help I M Stuck's Avatar
Help I M Stuck
when you say adjusted..what exactly are they not doing? Your rear brakes aren't what stop you..the front do all the work with the rear being secondary braking. So what you might think isn't working correctly might actually be working.
One way i know to adjust rear brakes is to run the vehicle in reverse and hit the brake..do that a couple times and see what happens.
Old Sep 15, 2004 | 08:53 AM
SShank42's Avatar
SShank42
Jack the rear up off the ground jack stand under each side. Take the plug out of the backing plate. With the vehicle in neutral adjust each side until I feel them drag when spinning the wheel. I can get in start vehichle, put it in drive, hit the brake, they stop spinning. Drive vehichle a couople of days no rear brakes. Jack it up put on stand but in drive hit brake, continue to spin.
Old Sep 15, 2004 | 12:53 PM
Help I M Stuck
check your brake lines from beginning to end for a leak? Or the Proportioning Valve might be bad...follow the lines from the master cylinder down to where they screw into a block shaped thing..that's the Proportioning Valve* ..that controls the flow of fluid to the front and rear..that could be bad.
Old Sep 16, 2004 | 08:10 PM
Ken00's Avatar
Ken00
Are you sure you don't have the adjusters switched, they are different for each side?
Old Sep 16, 2004 | 08:56 PM
Help I M Stuck
yeah, like Ken said..it might be in on the wrong side..or it might be in backwards..the end cap on the adjuster will be marked with a L or R.
