Front Axel Leak
2000 X, Limited, 4X4, 6.8 Ltr V10.Yesterday when I was rotating the tires on my beast I noticed an oil leak on the passenger side where the front axel comes out of the front differential. Can someone explain the procedure to replace this seal? Will the axel just pull out after I dis-assemble the tire, caliper, rotor and spindle housing, or do I have to open up the differential cover to release the axel? Are there any special tools needed to remove the spindle assembly and to replace this seal?
Thanks in advance for any help that is provided.
Robert
Don't pull it apart unless you have all the seals for the front end and the special tools to install them again.
I would start by picking up a shop manual for it.
