Rear Antilock light
Old Sep 14, 2004 | 12:37 AM
cnck's Avatar
cnck
Question Rear Antilock light
My rear antilock light is on in my 88 f250 and there is nothing wrong it has been on for a while now and the transpotation guys are out quite a bit now checking older vehichles and and i dont want to have to deal with them, i just want to get the light off so they dont make me take my truck in if they stop me. Any ideas would be great so thank in advance.
Old Sep 14, 2004 | 10:05 AM
zigman16866's Avatar
zigman16866
take out the bulb
Old Sep 14, 2004 | 10:13 AM
EPNCSU2006's Avatar
EPNCSU2006
The light on means there is something wrong with the abs system. There should be a black wire with an orange stripe with a connector on the end of it near the parking brake that you can ground out to make the abs computer blink out a code to tell you what is wrong with it. If you don't mind not having abs (it won't cause any problems) you can either unplug the abs computer module, or take out the bulb.
Old Sep 14, 2004 | 02:50 PM
Missileman740's Avatar
Missileman740
On an auto parts website that ends in "zone" they have the manual online for free. The troubleshooting chart for the RABS system is excellent there. Print it and follow it to diagnose yourself. Or, either pull the bulb or disconnect the module (above the brake pedal I believe in an 88) and the light won't come on.
Old Sep 14, 2004 | 03:16 PM
EPNCSU2006's Avatar
EPNCSU2006
That reminds me, I have some links that might help:
http://www.raybestos.com/OnLineTraining/abs-215.htm
http://www.brakeandfrontend.com/bf/bf99946.htm
Old Sep 14, 2004 | 03:48 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Your links didn't work for me. May be my computer, I have been messin' with it again.
Old Sep 14, 2004 | 03:58 PM
JLMoreno911's Avatar
JLMoreno911
its not your computer, those links are bad....
Parse error: parse error, unexpected T_STRING in /data/httpd/ford-trucks.com/htdocs/frameredirect/lc.php on line 79
is what shows up when you click on it...
Old Sep 14, 2004 | 04:01 PM
JLMoreno911
Originally Posted by cnck
My rear antilock light is on in my 88 f250 and there is nothing wrong...
you won't notice the ABS not working under normal use...its in an emergency when you slam on your brakes that it goes to work...stops it from locking and skidding your tires...
Old Sep 14, 2004 | 04:02 PM
Eric C.'s Avatar
Eric C.
Check the fluid level, that the float on the master cylinder is pluged in and the sensor on the rear differential is pluged in also. These are no cost and after fixing about a dozen of these when I work on a service truck for U-Haul this was a common problem with the older ones.
Old Sep 14, 2004 | 04:05 PM
EPNCSU2006's Avatar
EPNCSU2006
Copy and paste the links - they are good and work fine. The BBS tries to redirect and that is what isn't working.
Old Sep 14, 2004 | 04:09 PM
JLMoreno911
they do work when you copy and paste... :-)
If the fluid is low, wouldn't that trigger the brake light and not the ABS light??
Old Sep 14, 2004 | 05:45 PM
EPNCSU2006's Avatar
EPNCSU2006
Yes low fluid would turn on the red "BRAKE" light, and it might also turn on the ABS light as well, I'm not sure. Low fluid wouldn't turn on only the ABS light by itself.
Old Sep 14, 2004 | 05:59 PM
Eric C.'s Avatar
Eric C.
I was going on memories from a couple of years ago and was just remembering this would cause it. You are right that by itself low level will not cause the ABS light but will keep it after it comes on. also the fuse or no feedback from the valve it self.
Old Sep 14, 2004 | 07:22 PM
ingramo's Avatar
ingramo
You can also try pulling the plug that goes into the top of your differential and clean it off real good or you can check the fuse for the abs system. I had the same problem on my 95 and it turned out just being a fuse.
Old Sep 16, 2004 | 11:16 PM
cnck's Avatar
cnck
thanks everyone I will check this out this weekend and reply back when i figure it out. thanks again for the help
